Exhaust heat shielding?
  • Exhaust heat shielding?
    Having a look at the bits I'm going to eventually need for a underside resto and I've noticed that the rear heat shielding section at the rear has a hole where someone in the past has maybe moved it impatiently and a larger hole has been made around the clip that secures it, the less boring version is that it needs a new one as I assume you can't fix them?
    Are these RS specific (holds breath) or will any Mk1 focus one do, Jesus somethings got to be usable between the two.
    Any help as ever would be appreciated. ;)
    Afaik these heat shields are the same on all focus, not RS specific, but chances are they're NLA by now so you might need to source a 2nd hand one
    never drive faster then your guardian angel can fly
