If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I have, it's currently sat with no front wings on and has been stripped back to bare minimum on the front to have crash bar powder coated and replace power steering pipes, new charge cooler pump and bracket powder coated, basically any bit of bracketry and clips have been blasted and powder coated and generally giving it a good old tidy up but i just can't remember where this piece goes
Still hoping for more info on the attached pic of the part i'm trying to figure out where it goes, i'm not convinced it's from the washer bottle area as it's just too small for that so any ideas would be welcome
Ive just pulled my front wings and doing the excact same thing removing all small brackets and having them blasted and powder coated.
I have not come across anything that looks like that so far.
I will keep you informed if i find something out.
Al.
Have you had the scuttle panel off? There is a part which looks just like this which slots in the metal near the plastic scuttle arrangement just above the passenger side strut top is the easiest way to describe the placement?
Ok i'll have look into that
No I haven't, everything from there forwards tho, I'm sure its off the slam panel or in that area as i have different tubs of bolts and screws from dis-assembly but i just can't picture where it came from, it's probably going to be one of them obvious places as well
Have circled it for you in one of my photos that i've zoomed in on, apologies for the quality but it should be clear enough to help. 20190605_054059.jpg
